TwinTurbo.NET: Nissan 300ZX forum - If it's visibly leaking then obviously it should be replaced
Subject If it's visibly leaking then obviously it should be replaced
Posted by ThunderZ on July 26, 2008 at 6:38 AM
  This message has been viewed 145 times.
In Reply To Clutch or slave Cylinder posted by 93TTZME on July 25, 2008 at 09:02 PM
Message but you can also bleed the system and see if you get bubbles while doing it. If so, your Clutch Master is bad since it would be introducing air into the system. If not and the pressure appears OK while bleeding, then the slave might be shot.
Auto Zone has rebuilds w/ a lifetime warranty.
